Old Moto 4 Tranny Question
Hi guys, thanks for looking, please chime in if you can help!
BIL gave me an old Moto 4 Quad, either 200 or 250... The poor thing needs some work done badly, but hey it was free so I took it!
I'm not really familiar with maintenance, used ATV's for work, but never had to do maintenance myself.
For starters, the clutch was completely stuck, like it would not move an inch, no play at all... So we sprayed it, tapped it, changed the oil, tapped it again, let it sit for a couple of weeks... Today finally we were able to kinda shift it, the clutch is now able to move from neutral all the way up to what seems to be fifth speed. The quad runs but we cannot shift like a regular semi-auto... I have to get off the quad and push hard to put it back in neutral, impossible to move by foot.
Question is, any idea what causes that?? Is there anything I could add to oil to maybe clean it more without having to rip it completely apart or make some kind of adjustment??
Thanks all for reading this!!
I used to have an 86 moto4 with a stiff shifter. On the moto4 I believe its by either the shifter or foot brake i dont remember but its an adjusting nut that says increase and decrease. its for the clutch. mark where it is and turn it very slightly in either direction. if it doesnt do anything turn it back to the mark you made. turning too much will screw up the shifting. that might work a little.
To popular brands are Amsoil and Mobile1.
Well, after changing the oil again, riding it with only one speed I felt the clutch was moving a bit more freely after that. Sprayed the clutch lever with some Zep, moved the lever about one hundred times up and down, did some errands, came back, moved the clutch again, felt some resistance, felt something "give" in there and now it's back to working normally!!
Took the quad for a ride and it shifted up to third with no problem!!
I will change the oil again, and use some synthetic this time.
Thanks all who chimed in! Merry Christmas!
Logan Collins
09-05-2015 08:03 PM
