Yamaha Wolverine Winch Mount
Old 01-09-2014, 04:52 PM
wildfan97's Avatar
Default Yamaha Wolverine Winch Mount
I recently got a 2500 lbs Harbor Freight (Chicago) winch and need to mount it on my 2007 Yamaha Wolverine but dont want to spend $60.00 on a mount. Any ideas how to mount it? Any pictures would be great. If i cant figure out how to make a mount, what mount do you recccomend? I found one on Ebay that mounts to the frame and the bumper, only useing U bolts and has a mount for the rollar for 60.00. Any help would be much appericated.
Old 01-09-2014, 05:37 PM
Lehm4n's Avatar
Hi WF,
While I can't really answer your question, I will provide you the same feedback that was given to me --> Be careful with those HF winches; at the time you need it most, the real quality may let you down. Again, I haven't had one myself, but I'm working through the same process of putting a winch on my 660 Raptor, and that is what I was told. Makes sense though- by the time you get the winch full of water, dirt and grime, it may have a hard time doing its job.
Good luck with your project; I'm putting a winch on my Raptor and doing the same research.
Old 01-09-2014, 05:44 PM
wildfan97's Avatar
Thanks, and i bought the lifetime warrenty with it and I ride with people and most of them also have winches. I will not be useing this winch very much. Good luck finding one for your raptor.
Old 01-10-2014, 01:05 PM
TLC's Avatar
TLC
TLC is offline
You can make a mounting plate. Its just a plate or steel cut to the correct size with holes in the proper locations for the plate to fasten to the ATV and to fasten the winch to.
After buying a plate and cutting it and drilling it , $60 does not sound to bad.
Old 01-10-2014, 06:56 PM
wildfan97's Avatar
Thats what i was thinking. I guess i will just buy one. Thanks for the help!
Old 03-20-2014, 01:52 PM
RUBBERDUCK198's Avatar
When I picked up my winch from harbor sounds same as yours I just bought the 5 dollar winch plate they had there after few mods it works fine
toonces
10-19-2015 02:21 AM
MNatv89
08-10-2015 02:20 PM
Bratman2
07-23-2015 12:36 PM
Gtsordo
07-22-2015 01:27 PM
cornermike
07-08-2015 11:44 PM
Quick Reply: Yamaha Wolverine Winch Mount
