kodiak 450 diff light blinking
Old 01-31-2014, 09:32 AM
robsatv's Avatar
Default kodiak 450 diff light blinking
New member here needing some advice . Lets just say that my kodiak has been bullet proof until the yesterday ! Riding in 8-9 inches of snow i stopped for a break . The atv was in four wheel drive without the locker in . but the light started blinking. i tried to lock it in to see if it would stay solid and lock in but it wouldn't then tried taking it out , nothing i can hear it trying to do something but light won't stop flashing . limped home and pulled the plugs off the diff servo . thought maybe moisture . nothing . has always worked great not sure what made it start doing it . any suggestion on what to try would be greatly appreciated ! sorry so long
Old 01-31-2014, 12:29 PM
robsatv's Avatar
ok cleaned plugs on diff servo . jacked all tires up and ran it 4wd and diff locked up fwd and rev ! can't get it out of diff lock . you can hear it when pushing the button and it will go to 2wd but light continues to flash .
Old 01-31-2014, 12:51 PM
TLC's Avatar
TLC
TLC is offline
So now it will not move into any other modes of 3wd and 2wd? Its just stuck in 4wd Diff lock?
heres a few tips. Nyroc's ATV info website I know its a 660 but I think its the same system.
Also look into this.
http://forums.atvconnection.com/yama...cheap-fix.html
Old 01-31-2014, 12:54 PM
robsatv's Avatar
well just checked it by spinning the wheels by hand everything works like it should . front spin together when locked . spin opposite in 4wd on the front and i hear servos but diff light won't quit blinking.
Old 01-31-2014, 12:55 PM
robsatv's Avatar
thanks TLC not sure if this could be a CDI problem or not . just pulled those plugs and cleaned them
Old 01-31-2014, 12:58 PM
robsatv's Avatar
servos seem to work right but it not telling i guess cdi that its out not sure if there is a switch some where to check. lost .trying to play in the snow since we don't get much in southeast virginia ! haha
Old 01-31-2014, 02:46 PM
robsatv's Avatar
well i was a trip from the toolbox from pulling servo when a friend called back and ask about pulling battery cable off battery and seeing if it would reset ! well all is clear ! going riding now !
txpedsrt1
02-03-2017 08:07 PM
bzdok1234
30
02-23-2016 01:55 PM
07-28-2015 12:12 PM
RedRancher
07-10-2015 06:36 PM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
Quick Reply: kodiak 450 diff light blinking
