Yfz450 issue help!
Yfz450 issue help!
Just bought an 07 yfz450. Its been running great since i bought it a few weeks ago. Until the other day i was riding the woods and stopped to take a pee. I left my quad running and out of nowhere why i was sting by a tree the quad started reving up higher and higher by itself then it died. Now everytime i turn it on it revs high on its own Nd shuts off. Today i tried to start it and it would t even start. It happened out of nowhere while it was idling.. I checked my jets and they all look clean. I looked for air leaks around the boots and cant find anything. What could it be?!
You could also have an air leak around the exhaust manifold or head gasket. How hard were you running it before the idling, and how long did it sit idling when it first started? Is your radiator clogged? Cooling fan working? I ask this because they don't have the cooling reserve to sit and idle for long periods of time. It is possible the head may have warped if it overheated.
How did you check for air leaks? For whatever reason your air/fuel ratio at idle is to lean. Since it happened while running I would be suspicious of a blown head gasket/warped head. I would also look at the rest of the fuel system. Float heights adjusted properly? Nothing clogging the fuel cap vent or petcock? etc.
cody500ho
14
08-14-2015 05:03 PM
WesTech
11
08-11-2015 07:55 AM
