Big Bear engine swap
Old 03-08-2014, 12:36 AM
Joe04785's Avatar
Default Big Bear engine swap
How hard is it to do an engine swap on a 2002 big bear 400?
Old 03-08-2014, 09:21 AM
TLC's Avatar
TLC
TLC is offline
If its the same motor its just a bolt on/off swap. Can,t get much easier.
Old 03-10-2014, 10:15 PM
gangle04's Avatar
4 motor bolts, rmove swing arm to get rear drive shaft out, remove a front u joint to get the front, remove oil cooler lines, carb and exhaust i think that sums it up
Old 03-11-2014, 01:06 AM
Joe04785's Avatar
thanks all
Ean
12-19-2022 08:48 AM
bzdok1234
30
02-23-2016 01:55 PM
clsharky
07-13-2015 02:07 PM
tweeder
07-05-2015 01:57 PM
bzdok1234
Utility ATVs
07-03-2015 05:32 PM
Quick Reply: Big Bear engine swap
