1998 Big Bear 350 4x4 - Safe to stand up/roll back on rear
Old 03-31-2014, 10:50 AM
foolhardy's Avatar
Default 1998 Big Bear 350 4x4 - Safe to stand up/roll back on rear
I have a '98 Big Bear and I'm having trouble accessing the motor oil drain plug. I was wondering if it was safe, on this model, to stand the atv up on its rear end/rack so that the bottom is vertical. I have read that sometimes this can cause oil to get where you don't want it, depending on the model.
Thank you so much for your input.
Old 03-31-2014, 03:14 PM
I sometimes put quads onto their backsides to work on them, most often the 450 & 700 King Quads, in order to weld the frame. Some Big Bears still have unsealed batteries, which could leak, and I would turn the fuel tap off to prevent fuel from dribbling from the float bowl. I visited a big machinery auction a couple of years ago and a truck from Ireland was loading used quads bought at the sale, all the bikes were loaded upright, so tight together they wouldn’t be able to move on the sea journey to Ireland.
Big Bear sump plugs can be tight, that big flange gets quite a grip, I once had to chisel one off.
Old 04-02-2014, 12:23 PM
nukacola's Avatar
Wrench extension for more leverage. Moto 4 is the same way. Or use a little PB Blaster on it. If you physically can't get to it try ramps to get it loose then back it down to drain.
MikeyBoyesq
11-27-2020 02:44 PM
buckshit
09-24-2015 08:49 PM
txkevin
09-21-2015 02:02 PM
hoopduerr
06-02-2015 09:01 AM
Quick Reply: 1998 Big Bear 350 4x4 - Safe to stand up/roll back on rear
