96 Wolverine 350 Electrical issues
Hello, My 350 wolverine is blowing fuses when i try turn the key. I checked all the wires and they look fine. Has a brand new battery. Sometimes everything will work fine for a few hours and then next time i try it will just blow the fuse right away. Any help is greatly appreciated
The regulator does not go through the ignition switch on five wire regulators, which I think yours will be. The most probable cause is a wire frayed through and sometimes touching the frame. They are bad to find, though you sometimes get a puff of smoke and/or a smell of hot plastic from the offending piece of wire, just as the fuse blows.
