Kodiak 450 4x4 Problem
So, when I have the bike in gear and go to put it into 4x4, I'll hear the normal sound from the servo and the light on the dash will come on. But the 4x4 isn't pulling. Theres no kind of strange noises or grinding from the front dif like it's broke it just doesn't seem to be engaging. Could the servo not be engaging fully or something?
Any help with this would be great!
Thanks!
Cody
Thanks!
Cody
Try tis maybe. http://forums.atvconnection.com/yama...cheap-fix.html
Here is another. 501parts.com - Yahama Servo Motors
As well as the much talked of motor problems, the muff couplings also give trouble, put the handbrake on, jack the front up, start the engine, engage 4WD and check if you can spin the front wheels by hand, if you can (both wheels going the same way) and the prop shaft goes round, the muff coupling in the prop shaft has gone. When they fail they don't grind much, they just don't transmit power to the front end.
RedRancher
10-15-2020 01:45 PM
