1999 Yamaha big bear 350 fire problems
My big bear was starting fine rebuilt top end now will not fire when I jump solenoid nor will it turn over lights work switch works just won't turn over or fire really stumped new stator new starter new solenoid key switch new please can anybody help
If you have an ignition problem to begin with,just jumping the solenoid only allows the starter to turn the engine over. You can pull the plug cap off and check if you have spark with the bare wire against the engine when you jump the solenoid. If you do the resistor in the plug cap has blown. If no spark I'd trace where that blue/white wire you mentioned goes to and see if you accidentally unplugged the coil wire,etc. Not sure on Yamaha,but blue/white was the color for the coil wire on several Polaris year models. If none of this helps might be best to invest in a good manual that has the wiring schematic, trouble shooting guides on the ignition system,along with resistance specs for the stator and coil.Hopefully it's something simple if it worked fine before you did the top end.
