Check piston on 86 Yamaha moto4
Old 10-26-2014, 04:34 PM
woody2010's Avatar
Default Check piston on 86 Yamaha moto4
Just got an 86 Yamaha 225 Moto4 for $100. Seller said it ran when they last used it 10 years ago. I put a new battery in it and the lights work and neutral light works. It seems to shift fine. However I think the piston is seized up from rust.
What is my best option? I put some oil in the spark plug hole to let it soak a little while ago. Can I remove the top end without taking the entire engine out?
Old 11-06-2014, 10:26 PM
rider77's Avatar
Can you try and pull start it? Or is it defiantly seized?
I have a soft spot for these old machines. I have an '88 that I first learned to ride on
Old 11-07-2014, 02:50 AM
You can almost always get the head and cylinder off with the engine in the frame but you won't get the cylinder off if it is stuck to the piston. I would try taking the pull start off and rocking the crank gently backwards and forwards with a bar. Diesel fuel or easing oil down the plug hole is recommended by mechanics. Leaving for a couple of days to soak before freeing off is a good idea. If it is still stuck, take the head off and knock the piston down the bore with a block of wood as a drift.
Old 11-08-2014, 03:35 PM
woody2010's Avatar
I tried the rope starter with a strap wrench and have had penetrating oil in it for a week. I will try taking the head off. This is my first engine project ever so I appreciate the help.
Old 11-08-2014, 08:58 PM
woody2010's Avatar
Success! Top inch of the cylinder has rust on it, but I will use some 180 grit to see if I can remove it. Now on to the carb rebuild
Old 11-09-2014, 08:56 PM
Stretch67's Avatar
I have the same quad.
Regarding its former carb problems: https://atvconnection.com/forums/yam...00-carb-2.html
toonces
10-16-2019 12:11 PM
KimSJoh
14
07-18-2015 07:20 PM
Mojave250A
07-11-2015 10:38 AM
rcappie4
07-10-2015 04:54 PM
D-Hagz
07-04-2015 02:19 AM
Quick Reply: Check piston on 86 Yamaha moto4
