Banshee engine problem
Pull the fuel lines from each carburetor, stick them in a bucket or can and turn the fuel petcock on.
If a solid stream of fuel comes from each line, the issue is in the carbs, most likely pilot jets or float settings.
If no gas comes from the lines with the petcock on, you need to remove it from the tank and clean the screen/flush out the tank.
Good luck.
Good luck.
