Yama Breeze running rough / spark issue
OK I started a new thread because I have diagnosed the problem a little more and I think I'm heading in a different direction.
Here's the problem...
-The quad idles OK, but once you hold the throttle open a little it runs rough, stumbles, and if you hit the throttle to 1/2 quickly it falls right on its face and dies. After about a minute of holding it at 1/4 throttle it will stall out (it surges up and down a bit if you hold the throttle steady). When it stalls out, IT LOOSES SPARK (I pull the boot right off the plug and use a test plug on the cylinder fins and find no spark). As soon as I either turn the key off/on, or turn the engine stop switch to stop / run, it instantly gets spark back and will fire back up. Then again, after a minute or two it will do the same thing and the cycle continues.
When it runs it appears to be a tad smokey, and smells like a poorly tuned engine.
Ive got a new ignition coil and CDI box in it and the trigger coil is ohming out around 260. The spark appears to be a little weak (not a big blue spark, rather a little blue/white spark). Ive inspected the stator for cleanliness and it appears to be in good shape.
Any ideas?
Any ideas?
Hankey Pankey
26
10-18-2020 03:50 PM
SOLOLUCKY
05-25-2015 05:25 AM
