Warrior Neutral light don't work
Old 03-16-2015, 09:18 AM
Quadbc's Avatar
Default Warrior Neutral light don't work
Hi Everyone. I am new to the forum and see there are lots of posts on this problem. I have a 2001 warrior that I cannot get the neutral light to work. The bulb is good as is the main fuse. I changed the transmission switch and am getting continuity on the blue wire from it when in neutral. I checked the battery terminals and the battery ground to the frame. I even replaced the green relay under the seat. Oh, I should say, I can start it when I pull in the clutch. Runs fine but will not start unless I pull the clutch in..
Are there other grounds that I am missing? I have taken this thing apart several times and cannot find the problem. I even switched the brown wires from the reverse light and neutral light and no change. The reverse light works fine with either brown wires.. Any help would be greatly appreciated.. Thanks.
ripperray
10-10-2023 02:42 AM
Mkp
03-28-2020 03:50 AM
jonathongolden250
06-23-2015 04:36 PM
Nelson
06-20-2015 01:59 PM
jayking232003
06-09-2015 02:54 PM
Quick Reply: Warrior Neutral light don't work
