06 Yamaha Bruin 250, need help please..
Old 03-27-2015, 12:20 PM
DQuick74's Avatar
Default 06 Yamaha Bruin 250, need help please..
I just got a 2006 Yamaha Bruin 250.. I am having a problem getting it started, I can pull start it but it takes awhile. I have drained all the old gas and put non- ethanol gas back in it, new starter, new spark plug and new solenoid.. when it gets hot it will crank with the starter button no problem, why wont it start when it's cold? It does turn over and is firing with the start button just wont bust off... please help.. thanks.. oh and I cleaned the carb. out..
Old 03-27-2015, 12:45 PM
ATV_MAN's Avatar
Sounds as if your battery is dead or close to it. Do you have a multimeter to test with? The battery should read 12V+ when the engine is cold, if not then that would explain why its easy to start after its been running because of the stator charging the battery.
Old 03-27-2015, 03:04 PM
DQuick74's Avatar
yes I have one and a charger, Ill give it a try over the weekend thanks a lot...
Old 03-27-2015, 04:50 PM
DQuick74's Avatar
the battery is fine 12.5 volts. if you can think of anything else please let me know. a relay maybe?
Thanks, Dan
buddieboy
12-09-2016 05:50 PM
Barnsnelbon
09-27-2015 03:07 AM
Bernhard
09-25-2015 12:45 PM
jbrewster94
09-23-2015 04:16 PM
09-23-2015 06:23 AM
Quick Reply: 06 Yamaha Bruin 250, need help please..
