Yamaha bruin quits running
Old 04-22-2015, 06:56 AM
Zuber's Avatar
Default Yamaha bruin quits running
If you run slow it will run all day but, if you run it fast it will go about a mile
And die. It back fires when it dies. Wait a couple seconds and starts right
Back up and it will run about another mile and die. Always starts right back.
Old 04-22-2015, 08:19 AM
TLC's Avatar
TLC
TLC is offline
Try running with the gas cap off to see if its a gas venting issue , it happened to my 350 Big Bear.
Old 04-22-2015, 09:09 AM
Zuber's Avatar
Have already try running without gas cap and it
Didn't help. Thanks.
Old 04-24-2015, 08:50 AM
Zuber's Avatar
Could it have something to do with my main drive
Belt slipping causing my transmission to over heat
And shutting it off? It's a 04 and belt never been
Replaced. I can run high RPMs for 10 mins and it
Does not quit.
Old 04-24-2015, 09:10 AM
TLC's Avatar
TLC
TLC is offline
Belt would not cause it to stall. Another thing that happened to my 350 Big Bear was it had a ignition coil that would that would quit after it ran for awhile and once it cooled back down it would run again.
Old 04-26-2015, 08:37 PM
Oldbear's Avatar
I tend to go with the coil being weak and when it gets hot quits.
Old 04-26-2015, 08:43 PM
Zuber's Avatar
Default 04 350 Bruin quitting.
I'll try a coil. Thanks for your reply.
Wooodyii2
11-16-2020 07:14 PM
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
chinkapin
07-14-2016 06:58 AM
tycobb
ATC 3-Wheelers
10-23-2015 07:37 PM
sticky123
06-14-2015 07:36 AM
Quick Reply: Yamaha bruin quits running
