2001 Yamaha Warrior Wiring Problem
Old 06-16-2015, 09:02 PM
njrider64's Avatar
Default 2001 Yamaha Warrior Wiring Problem
2001 Yamaha Warrior YFM350 - Was riding at lost trail in PA when it crapped out on me. Had a bad battery which had massive leaks, replaced it with a new one. One of my buddies suggested that the acid went straight through the harness. Had good compression and motor was running better than ever (new carb) and now it has no spark. Spark plug is fine. CDI possibly? Dont want to buy a new one and have that not be the problem. Any suggestions? Diagrams?
Old 06-16-2015, 10:19 PM
beyondupnorth's Avatar
Do yourself a huge favor and got to tradebuit.com and buy a Factory yamaha repair manual for @ $10
The test and procedure you need will be in there
Old 06-17-2015, 03:32 AM
Did the battery split or boil? If it boiled, the regulator is faulty, you may get away with fitting a new regulator but it could also have cooked the CDI. beyondupnorth is right though, a good manual can save money on un-needed electrical components.
Old 06-19-2015, 03:08 PM
ag2560's Avatar
Most of the time no spark on a warrior ends up being a stator. If you have a OHM meter you can check the resistances on the plugs that come out of the stator. If you have any questions PM me and I can give you some help.
Old 04-15-2017, 09:18 PM
Jlebouef's Avatar
maybe you can help me i have a 91 warrior put new cdi rectifier stator coil on and it is not firing what could it be
Old 07-04-2017, 01:34 AM
moefie35's Avatar
Default And
Help on wiring
Old 07-04-2017, 01:40 AM
moefie35's Avatar
Wher does the wires go...from relay..i bought this and just realized the headache im about to have where do wires go from starter solenoid..i know 1 goes to positve and does the ther go to starter motor. Or?...not getting fire just turning over..it crunk a few times now nothing just turning over..spark plug good
Originally Posted by moefie35
Help on wiring
mikey426
06-17-2015 03:53 PM
generalpops
06-05-2015 08:23 PM
generalpops
06-03-2015 08:25 PM
dano00
10-07-2000 08:13 PM
dunc_n
08-26-1999 09:32 PM
Quick Reply: 2001 Yamaha Warrior Wiring Problem
