What are these two ATVs $800 apart?
I was comparing a "base" eps Grizzly to a "loaded" SE Kodiak, the video is comparing a "loaded" Grizzly to a "base" Kodiak.
The base Grizzly does not have nice rims like the one in the video.
The SE Kodiak vs the base Kodiak has many differences.
-Diff lock
-On command push button 4wd not mechanical have to stop shifter.
-Adjustable pre load suspension the base is non adjustable.
-High end alloy rim. The base Grizzly and Kodiak both have plain steel rims.
2016 Yamaha Grizzly EPS Steel Blue ATVs odd the Kodiak is lower yet has the same ground clearance, only difference is because of the tire size. 25 vs 26 . Must be due to seat foam?
They both have the same 4.76 Gal tank yet the Kodiak has storage compartment in the tank also
-Diff lock
