Can someone explain how different size CVT weights impact engagment
So I was doing some reading on how the CVT weights on the new Kodiak 700 are about 18 grams whereas the weights on the Grizzly 700 are about 33 grams. My question is given that the Kodiak and the Grizzly have the same engine and drivetrain how would the lighter weights impact the CVT on Kodiak? And how would it make the Kodiak feel as compared to the Grizzly? I simply do not know enough about CVT to visualize this
Oh dear, why do makers call variators "clutches" when they are not, at least not on Grizzly 550s, so almost certainly the 700 will be the same. They have standard centrifugal clutches like manual Hondas and old Yams. The variator rollers control at what revs, it changes up and down gears, light rollers and the machine seems low geared, heavy and it seems high geared.
That does seem like a easy swap. That sounds too easy though. For probably under $100 you could change out the clutch weights. The Grizzly probably has a thicker cvt belt as well as different pulleys. So you'd need to change those out as well. It probably is geared different too. But simply changing the clutch weights and springs would definitely give you a performance boost, just wouldn't be all that would be necessary to make it equal to the Grizzly.
Can't weigh up this idea of changing rollers giving a "performance boost". I've just rebuilt an Eiger Variator, the belt box was full of oil and the front nut had come loose, luckily only damaging the grease seal on the outboard bearing. With new seals all round, a new belt and the oil cleaned away, it runs fine but is particularly low geared (all Eiger Autos are) and you just sit there with it reving away and not going very fast. There must be a "sweet spot" for roller weights and springs where the bike changes up at the perfect time, The Grizzly 550 is about right as are the Suzuki 450 to 750s.
Only difference part number is the $6 weights between the two.
Cam is even the same part number.
To expensive production wise for Yamaha to make two separate clutches for the same motor.
The thing about weights and clutching is you take one from the other. If heavier weights have a advantage some where then lighter weights will have a advantage in a other place in the power band.
People who clutch for oversized mud tires but then return to normal size tires often re-clutch once again.
The difference we're talking about here might not really be that great in the first place. The Kodiak 700 still has the same 48hp 708cc engine. Even with slightly less aggressive clutching than the Grizzly, I bet it still has plenty of low end thump. You'd have to ride both machines to really know the difference. Its not something you can quantify by reading about, you have to get a seat of the pants experience to know for yourself.
