2004 Yamaha warrior makes chunk in noises
My Yamaha warrior 350 started making loud chunking noises while driving so I turned it off right away
The motor oil was close to the min line so now I don't know if it ran out of oil or if it's something else the motor still turns so it's not seased I'm really disappointed is there any way to fix this without spending a lot of money?
We need a little more info. When does the machine make the noises? Is it all the time, at idle, only while moving? It could be anything from valves out of spec, bad bearings or bushings in the a arms or axle, or you are close to catastrophic engine failure. If it is AT the minimum oil level, you are still within spec. Is the oil fresh, or 5 years old, lol?
