21cc on stock pistons
The larger domes are going to be a safer bet to run pump gas. Not a lot of Banshee guys around here anymore unfortunately. I would try contacting the head manufacturer, or if your engine has been ported/stroked your builder may be able to help. In the end, you just may need to perform a good old fashioned squish test to make sure you are in the right compression range for your desired octane rating. I know some of the 250r forums are good resources to find the squish test procedure. Good luck!
I would go with the 20cc's. I have 17's in mine and I need to run race fuel. I had my stock head milled .010 on my other one and can run super in it. My 4 mil has 180 psi cold compression and the other has 150. 165 and up is where you need race fuel and 145 and up for super. Check compression after you install them to see what fuel to run.
