Fuse blowing
The fact is that the fault can be anywhere between the main fuse and any sub fuses. However the voltage regulator must be a suspect. I get a 12v test bulb and put it in place of the main fuse, if it glows without the ignition switch on, the fault is between the fuse and the switch. Disconnect the regulator, if the light goes off you have found the fault and need a new regulator. The light will come on anyway, when you switch on the ignition and a fault beyond here can be in many different circuits, so a wiring diagram is needed.
Thank you I will try the test asap.
[/B][/B]
spacex
21
01-18-2016 07:19 PM
stow_senior
13
12-18-2015 01:20 AM
