Raptor 350 choking out
I gotta raptor 350 it was running fine then bogged out n stalled n it was like the battery was dead then I jump started it n it wouldn't start unless choke was on full n if u hit the throttle it will bog n stall or turn choke off it boggs n stalls any ideas what the problem maybe?
Check the battery and connections out first.Check/drain fuel if you suspect it of being a problem. If it still acts up,might be time to go into the carb with a new kit.Shindy Carb Carburetor Repair Kit for Yamaha YFM350R 04 08 03 322 | eBay
Again load test the battery and check connections as a bad battery can cause problems. If you've eliminated this,then if rpms still rise when it gets warm,it could be running lean on jetting or you may even have an air leak. When it revs up you can spray some wd40,contact cleaner around the intake manifold,head and base gaskets and see if engine rpms drop.If it doesn't then I'd crack open the carb.
Tightened up battery connection clean all connectors put jump pack on to jump start it fires right up throttle response is there now but backfiring n popping in carb is still there
If you have to go into the carb,remember this kit.http://www.ebay.com/itm/Shindy-Carb-...mtr&rmvSB=true
trouttracker
01-08-2016 02:07 PM
trouttracker
01-03-2016 04:48 PM
