big bear squats in rear in reverse
Old 04-10-2016, 09:55 AM
dart440's Avatar
Originally Posted by dart440
Just found some.. hopefully have them installed this week.. thanks again.
Well ...I installed new ujoints and still have same problem.. so with the front drive shaft off I have no resistance when pushing quad in netruel(forwards or backwards ) but when front drive shaft is installed, when I push the quad forward (10 feet) the rear of quad pulls up. And when push the quad backwards in netruel (10 feet) the rear of quad sucks down . I was thinking maybe the drive shaft yoke phasing was incorrect maybe. I can't figure this one out... any advice would be appreciated... thanks
Old 04-16-2016, 01:29 PM
Have you got the same outside diameter tyres front and back. I once repaired a Honda 300 that would jump every so often. The frame had broken just behind the front diff, because the tyre sizes were a bit out, front end and back parted company until the front drive shaft spline came out, pressure released, it popped back in again and repeated.
Old 04-17-2016, 05:50 PM
dart440's Avatar
Thanks for the reply. ..
They are the same size (tires) , they are actually original from 1989. I was thinking the same about the tire size, then I got to thinking , the previous owner told me he did some work to the rear end so I was thinking maybe he replaced the rear differential that had a different gear ratio than the front differential. I don't know if the big bear even had different gear ratio's but I know that front and rear have to match.
Old 05-13-2016, 08:15 PM
dart440's Avatar
Still have the problem... anyone know of a Yamaha forum that can maybe be of some help? Thanks
  #15
Old 05-14-2016, 09:46 AM
Fasteratv's Avatar
Try the grizzly forum....maybe they can shed more light on this particular subject/problem.
  #16
Old 05-16-2016, 12:05 AM
dart440's Avatar
Thanks.. I will
mustangmatt70
03-29-2016 08:04 PM
Bee Szz Noo
Sport Quads
10
02-29-2016 12:11 AM
Snky
02-08-2016 07:13 AM
gearhead1985
01-27-2016 09:02 PM
mustangmatt70
01-04-2016 04:45 AM
Quick Reply: big bear squats in rear in reverse
