Quad hasn't been used in over a year.
^^^ Depends on several things. A persons knowlegde/ability to correctly clean a carb ( Primarily the various jets )....and this is an unknown ( to me ). Two more unknowns ( for me ) are the condition of the needle valve and bowl "O" ring ( age of ATV ). IMO, an inexpereinced builder will have "better luck" with installing the new parts and is taking a chance on many possible problems by "only cleaning" the carb and reusing the old parts.
Why do you think cleaning the carb should be good enough?
Altho with the leaking by the needle issues lately by far have been ethanol related, and new needle/seats do nothing for that is why I questioned the kit.
O-rings around the seat along with the viton needles that a lot of machines still use that can be deformed and eaten up by ethanol and just by sitting in un stabilized fuel..? Not understanding what you mean. Plus I've found a lot of black specs in fuel bowls(especially older carb models) where ethanol has been eating up the insides of fuel lines.
"Circulating" along with stabilizing.. Learned the hard way on this one myself on the old Honda before I sold it. Heat can evaporate fuel through the vent lines if sitting up and cause problems even if stabilized like I had to go through a couple years ago.. Just for 4 little pilot jets.. Carbs had to come off,pilot jets cleaned and synchronized. Glad I'm through working on carbs.. Here's some spotless carbs,but wouldn't idle after I let it set up because RA was flaring up over the months and wouldn't let me ride.Plus got lazy and didn't crank it up now and then like I had in the past..
https://atvconnection.com/forums/gen...-not-i-do.html
#15
#17
#18
Same old story......you can take the time to do it right or you can keep redoing it until you learn to do it right. In my 66 years if there is one thing that I have learned is take the time, spend the extra to do it right the first time,.....or keep trying over and over and over, then after a while you will learn to do it right the first time. It just takes some longer to learn that, and yes I was one to learn the hard way. Yes on occasion we can get lucky with taking short cuts but in the long run you will find a short cut takes more time and money than doin it right to start with!
#19
I appreciate all yalls feedback, but i haven't gotten around to it yet. I did manage to start the quad and it started without any problems. I also rode it around the neighborhood a bit. I notice most carb problems result in the quad not starting at all, Does this mean it's fine or should i still rebuild the carb? Im not really well educated in this so im sorry if it sounds a little ignorant
#20
