2000 Kodiak 400 installed known-good carb, but still won't start
Ah yes...was thinking 2-stroke...sorry! Well...you're definitely getting fuel, you say you have spark...I'm down to compression and timing...I wouldn't think the valves out a bit would keep it from starting...unless one is bent and stuck open/close.
How quickly did the engine flood with fuel? The leak-down past those rings should be pretty slow...
Short answer is yes...improper valve seating will impact compression. Does your head have valve windows to check them? Either way if you get a lower than spec compression reading you're probably going to need to start tearing it apart...not a fan of thumpers for this very reason...too many moving parts IMHO...
If the airbox is full of fuel, the you built the carb incorrectly and it's flooding. Re-visit the carb, get it right, change the oil again and install a new spark plug.
#15
Thanks, but I think you missed the post where I switched carbs with a known good one, and it still will not start.
#16
If you cleaned the airbox prior to installing the second carb ( I assume you did...LOL ), and the airbox is full of fuel again, then the float is hanging/stuck or you have the fuel line connected to a carb vent instead of the fuel inlet.
#17
The airbox is not full of fuel again.
#18
#19
Do you have a manual? I'd think there would be timing marks somewhere to assist in TDC/valve lash adj. Every machine is different and I'm no expert on the thumpers...
