Any Moto 4 gurus?
If Yamaha did put the solenoid ground through the CDI, they would have a reason, such as the CDI needing a signal from the safety "lock outs" on brakes or gearbox before allowing the starter to get power. It could be that one of these lock outs, or a wire from it, isn't working so the CDI doesn't get the signal. A 13 wire CDI is so complex, you are best getting a workshop manual to check the system over properly, before buying new components.
Does the source coil send AC voltage to the CDI as the flywheel spins around it? Since the pickup coils are two wire, does the CDI send DC or AC voltage in one wire and when the proper spot on the flywheel meets the pickup, does it then send power to the CDI telling it to spark. That's the info I need so that I can then create a stand alone harness for the bike that deletes all the far outdated unnecessaries.
The problem is, your stator/pickup coil set up is downright weird. Standard set up for AC CDIs is:- one phase of alternator wired into CDI, this provides the AC power. One wire from pickup coil to CDI (other wire earthed to engine), this provides the timing signal also AC. Some older systems have a separate alternator coil providing the AC power, which would explain the odd looking coil on your stator, but four wires from the pickup coil? We need Lyn Edwards back for this one.
No spark issue solved!!
I changed everything! stator,coil,key switch, battery, plug, cdi box still light to weak just enough to light in line plug light but not enough to spark a plug!
it was the rectifier!!
dont let any clown say that
it doesn't tie in with the spark that is bull
it does!
happy riding dor65!!
Dahlgren off road 65
it does!
#15
Very common on Honda 450FMs. Don't know why, but if the regulator fails on one of them it usually won't spark.
A full AC CDI ignition is completely separate from the charging circuit, but from 1990s to when bikes changed to EFI systems, most of the "big four" maker's bikes had a sort of hybrid ignition system, part powered by battery, part from an AC coil on stator.
04-13-2016 06:57 AM
chuck1177
03-06-2016 02:23 AM
