Need help with 03 yamaha raptor 660
Hi everyone. I honestly can't go through those 2600 pages or so of past posts to find a similar issue with my 03 yamaha raptor 660. It has a k&n DG exhaust ...carb has 25 and 140/145 and needles at 2nd clip from the bottom (towards the point) it runs fine till about 3/4 throttle then starts to struggle almost dies then back fires then it goes good for 3 seconds then starts over. Carb has been cleaned very well and has new o rings and gasket..both springs are matched to spec kinda lost..do I need a 150/155? And needle set at the middle?
I did that today actually with bigger jets and runs alot better now...get the odd snappy back fire once and a while but still can't hard hot the gas from idle...u can see alot of fuel pour in so adjusted the needles and removed the washer inside...I went to a 160 165 too much money to get some in betweens.
I thought the air mixture screw was only an idle thing? I don't really want to remove the whole intake assembly again.....did it about 17x yesterday lol but has to be check fully assembled to get accurate readings. Both screws are at 2 1/2 out and no hesitation on idle or above 1/4 I decided to modify my own jets going to the local dealer was over 100 bucks and that's getting a little much. I did adjust the needle to the lowest point and runs pretty good just like I said has that sputter once in a while
