Starter don't grab right away
Old 11-20-2016, 01:21 AM
Cody Moermond's Avatar
Default Starter don't grab right away
I have a 99 yamaha warrior and the start will spin and spin free and then after a little you can hear the starter slow down then it turns the motor and starts. this has been getting worse and worse I have no idea what can make it do this please help!
Old 11-20-2016, 05:21 AM
Check the starter gears for missing teeth, but the most likely cause is the one way starter clutch failing. It will be behind the flywheel, which will have to come off to fit a new one.
Old 11-20-2016, 10:02 AM
I wouldn't think it the gears because the start will just free sspin then slowly start grabing and then turns the motor thank you for the help
Old 11-20-2016, 12:24 PM
hydrex's Avatar
I would also check the battery voltage.
Old 11-20-2016, 02:46 PM
It's a brand new battery and even with batter charger on start engine it does it
Old 11-20-2016, 04:42 PM
When hooking jumper cables you to it it still does it I'm going to look for a short somewhere
Old 11-20-2016, 05:42 PM
I've had worn starter clutches slip and grab like this also.
Old 11-20-2016, 08:35 PM
I found some wires broken but it still ran and started so fixed them but still did it took the side cover off and see you have to have some kinda tool to the the fly wheel off but I should only be able to turn it clock wise right? All the gears are fine but I can turn the gears both ways
Old 11-21-2016, 04:29 AM
Then it is the starter clutch, and yes you need a puller for the flywheel.
Old 11-24-2016, 02:13 AM
Okay so I replaced the starter clutch and one way bearning helped but still spins for a little before spinning and when I took the old one off the bearning was locked up and stuck on the gear
