No power problem
power problem 2003 yamaha kodiak 400 4x4
I have a 2003 yamaha kodiak 400 4x4 I changed a blowed ignition fuse it has a good battery in . but when I turned the key on no power is coming on at all no lights or starting button is working I checked all fuses they are all good on the solenoid an the fuse box but still when I turn on the key there's now power at all its in N an everything I'm stumped can someone help me
All fuses are all good here jus changed one bad fuse from fuse box was the 10 amp for the ignitio fuse
This pic an down is jus shots to view it all worked when i parked it someone stol my carb so i bought a new on am installed it now i cant get power to start it
I checked all plugins an all is good an pluged in an none cut
Key is on no power
