starter won't disengage
Old 01-24-2008, 08:04 PM
hndgnr's Avatar
Default starter won't disengage
I would appreciate some help. where to start . My 350 warrior 2001 starter will not stop starting even with kill switch off even with the key off. Ihave to unhook the power. Thanks for any help. Jerry
Old 01-24-2008, 08:21 PM
DIRT FREAK's Avatar
sounds like the solenoid is not disengaging causing the starter to keep turning over.disconnect what is powering the solenoid to see if it quits,if so you need a solenoid.as a mechanic i have seen this many times.
Old 01-24-2008, 09:53 PM
beefy46172's Avatar
Loves To Ride!
Tap on the solenoid (it is the little canister in a rubber boot under the left rear fender) and see if that stops it. It sounds like it may be stuck.
Old 01-25-2008, 03:34 PM
imsam77's Avatar
beefy you took the words outta my mouth...it might have to be replaced...i never heard of one of these going on a quad?
Old 01-26-2008, 12:48 AM
beefy46172's Avatar
Loves To Ride!
Well, they seem to be fairly rare, but that really is what fits the bill for this problem as it sounds, at least. They are about $25 to replace.
Old 01-27-2008, 06:23 PM
hndgnr's Avatar
thanks everyone you are correct. Jerry
Old 01-27-2008, 08:04 PM
beefy46172's Avatar
Loves To Ride!
Glad to hear you got it fixed.
Old 03-12-2017, 08:43 AM
1175pioneerman's Avatar
Default starter
1999 Yamaha Kodiak 4+4 350 motor what causes the starter to run but the motor does not turn over new solenoid new ignition key & new starter harness wires no luck any ideas fellas.
Old 03-12-2017, 01:00 PM
Sounds like your starter clutch or an idle gear is shot,just spins with the starter motor and not engaging.Item #11. 1999 Yamaha KODIAK 4WD (YFM400FWBL) Starter Clutch | Cycle Parts Warehouse
Old 03-13-2017, 02:37 PM
Default starter turns the wrong way
1999 Yamaha Kodiak 4+4 350 starter clutch ok. all the gears looks good the starter when you turn ignition on the starter starts to turn over like if there is something stuck new starter solenoid new ignition switch new light switch some one help don't know what to do I did notice like the starter it self was turning the wrong way
Johnny Mac
08-15-2019 03:13 PM
Lucas Bohanan
09-29-2015 01:16 AM
wrencher82
09-28-2015 10:02 PM
kbazzy
09-26-2015 11:26 AM
95scramblerruben1033
09-23-2015 06:29 PM
Quick Reply: starter won't disengage
