2003 Honda Rincon series
| Honda’s 2003 Rincon, Part Two. The SUV of ATV’s! |
The new Honda Rincon has had one up-grade from past models. Still using drum brakes in the front, but a rear disk brake
has been incorporated to the drive shaft located in front of the rear differential. The new disk brake uses a collet-type caliper. Several advantages to the disk verses the larger drum set-up are less weight, increased ground clearance and improved maintenance. We felt positive braking with the Rincon, the unit handled well and slowing was never a problem.
Suspension upgrading is something we were really glad to see. The Rincon has the most comfortable ride in the industry. Starting with a large plush seat then moving down to the cushy fully independent suspension and finally, radial tires. These components provide a comfort which no ATV rider has ever felt. The suspension up-grade begins with independent
double-wishbone A-arms front with 6.9 inches of travel and a new fully independent double-wishbone A-arm rear with 8.0 inches of travel. The Rincon’s suspension uses long travel coil-over shocks with no adjustments. Honda chose to use aluminum upper A-arms with steel lower A-arms in the front to keep up durability. In the rear, aluminum upper and lower A-arms support the well designed independent suspension. The aluminum upper and lower A-arms produce a substantial weight savings. Both are
mounted to the rear differential which is integrated and mounted directly into the frame, producing a light and efficient set-up. The rear suspension uses a aluminum sway-bar to track and moderate body roll. Honda has again produced state of the art fully independent suspension on the Rincon. Our only complaint stems from a bit to much body roll. We would like to see adjustable shocks added and possibly some adjustment to
the rear sway-bar. Riding the Rincon in a very aggressive manner produced some situations where the rider felt that cornering the unit at high speeds produced extensive body roll. We realize body roll is a trade off for the comfortable ride but, also, realize that turning up the preload on the suspension would help extensive body roll especially with heavier riders. That’s where adjustable shocks would help personalize the ride and handling.
Comfort is the Rincon’s middle name. All controls are user friendly and within easy reach. A thick padded seat uses dual-density foam to provide all-day riding comfort and the right
floorboards allow the rider’s feet to grip the footrests while keeping mud and debris off of the rider. A large multi-function LCD digital instrumentation is compact, tough and waterproof. Featuring readouts in what gear is selected, speed, odometer, resetable tripmeter and hourmeter/clock. The instrument panel includes LED lights for drive, neutral, reverse and temperature warning indicator. Also, a digital fuel gauge is displayed in the readout window. All handle bar mounted switches and controls are easy to read and easily accessible. Other handlebar controls, include parking brake and choke lever. Other features, include a large light weight plastic fuel tank with 4.5 gallon capacity, 12 volt waterproof accessory socket, side opening compartment with 4 liters of storage and large cargo racks capable of 66lbs. front and 133lbs. rear. Dual 40-watt halogen headlights and dual brake/tail lights are standard lighting. A trailer hitch is offered as an option.
skills. The Rincon has been produced to give a fun, sporty ride with a subdued work ethic. We feel Honda has put together a good unit with the potential to run Baja and come out in the lead. Once a rider gets used to the Rincon a complete package unfolds. The Rincon proved itself in the desert area of the Grand Canyon but we all wonder how will it handle the step mountains of the North East? We are sure it will do well but we are excited about spending more time in the seat. As journalists, it is our job to ride and report our thoughts about each machine. This is a much easier
job than designing one of these new ATV units, but doing our job sometimes entails making statements about improvements to different models. It is very difficult to decide if the machine really needs to be improved or is this improvement a personal choice. Like needing more power, not all riders need gobs of power. We need to find a middle point of deciding what improvements are needed. We feel
the Rincon can be improved with adjustable shocks and a bit more bottom end power level. The Rincon unit is about as perfect as a Recreational Utility unit can be and that’s why it is so hard to pick improvements. If the Rincon is on your wish list, you need to get to a dealer and check the unit out. Honda put three years of design into the Rincon and has come up with a sporty unit that excels with each trail! Engine Type 649cc liquid-cooled OHV semi-dry-sump
longitudinally
mounted single-cylinder four-stroke
Bore and Stroke 100.0mmx82.6mm
Carburetion 37mm CV
Ignition CD with electronic advance
Starter Electric with auxiliary recoil
Transmission Automatic
with hydraulic torque
converter, three forward
gears and reverse
Driveline Direct front and rear drive-shafts with
torque-sensing
limited-slip front differential
Suspension Front Independent double-wishbone; 6.9 inches
travel
Rear Independent double-wishbone; 8.0 inches travel
Brakes Front Triple-sealed hydraulic drum
Rear Single hydraulic disc
Tires Front 25 x 8-12 radial
Rear 25 x 10-12 radial
Length 8.37 inches
Width 46.1 inches
Height 47.5 inches
Seat Height 34.5 inches
Ground Clearance 10.0 inches
Wheelbase 50.8 inches
Turning Radius 10.8 feet
Dry Weight 600 pounds
Fuel Capacity 4.5 gallons,including 1.0 gallon reserve
Colors Red, Olive
* Meets 2008 CARB emissions standards
Special Thanks to: Honda’s Lee Edmunds.
www.Honda.com
