2005 Suzuki Eiger 400 2×4 Manual shift
2×4 Manual-shift
undefined
All Eiger models feature a dependable 376cc single cylinder, four-stroke, air/oil cooled SOHC 4-valve engine, with 9:0:1 compression ratio, a single 32mm Keihin carburetor, a gear-driven balancer to reduce vibration, and a wet sump lubrication system. Power is transmitted through your choice of an aotumatic transmission featuring a fully automatic V-belt, continuously variable gear ratio, or a manual 5-speed with reverse transmission combined with centrifugal automatic clutch and 2-speed sub-transmission. Automatic models utilize an advanced braking mechanism and 2-speed sub-transmission with reverse gear. In addition, 4X4 models feature Suzuki’s unique torque sensing limited slip front differntial and an easy to use handlebar mounted 2WD/4WD control lever.
The Eiger frames are created with a large diameter, thin walled tubing for maximum strenght and minimum weight with agressive bodywork, high radius fenders, a rugged style grill and large front bumper for a bold and sporty look.
The front suspension features an independent double A-arm design with a class leading 6.69 inches of wheel travel and dual shock swingarm rear suspension with 6.69 inches of wheel travel and 9.3 inches of ground clearance. Braking duties are handled by dual 190mm front dics brakes combined with a water-resistant drum brake mounted at the rear.
Features
  • N/A
Specifications
  • Engine:4-stroke, single-cylinder, air/oil cooled, SOHC
  • Displacement:376cc (22.9 cu. in.)
  • Bore x stroke: 82.0 mm (3.228 in.) x 71.2 mm (2.803 in.)
  • Compression ratio:9.0:1
  • Carburetion:Keihin CVK32
  • Ignition:Electric & recoil
  • Transmission:5-forward, 2-subtrans. w/reverse
  • Final drive:Shaft drive
  • Frame:
  • Suspension front / wheel travel: Independent, double Aarm, oil damped / 170 mm (6.69 in.)
  • Suspension rear / wheel travel: Swingarm-type, oil damped / 170 mm (6.69 in.)
  • Front tire: AT25 x 8-12 PP
  • Rear tire: AT25 x 10-12 PP
  • Front brakes / rear brake: Disc / Drum
  • Overall length: 2175 mm (85.6 in.)
  • Overall width: 1145 mm (45.1 in.)
  • Wheelbase: 1270 mm (50.0 in.)
  • Ground clearance: 235 mm (9.3 in.)
  • Seat height: 830 mm (32.7 in.)
  • Lighting:
  • Rack capacity, front / rear:
  • Towing capacity:
  • Fuel capacity:
  • Dry weight: 542 lbs.
  • Instruments:
  • Color choices:
  • MSRP:
