2006 Arctic Cat 400 Class
2006 Arctic Cat 400 Class – Multiple Models Equal Many Smiling Riders
undefined
Diff erent riders have diff erent needs, which is why Arctic Cat makes a variety of their popular 400 class 4×4 ATVs. Riders who demand the only true fully independent rear suspension (FIS) can opt for a 400 4×4 with either the Duramatic automatic transmission with engine braking, or with a fi ve-speed, auto-clutch manual transmission with Hi-Lo range.
Every 2006 FIS model is equipped with new slimline SpeedRacks featuring a contoured shape and new accessory attachment mounts that lower the height of the rack. The FIS models also receive a full-lock front diff erential (with a convenient handlebar-mounted lever), fl oating brake calipers, a redesigned hydraulic foot brake system with remote fl uid reservoir and a heavy-duty rear axle.
A new digital instrument pod on the FIS machines has 14 digital indicators such as speed, odometer, dual trip meters, hour meter, clock, and fuel level that is enhanced with new bodywork that gives the 400-class the Cat Family look.
All of the Arctic Cat 400 class machines are powered by a torquey 376cc, air/oil-cooled four-stroke engine featuring a temperature-controlled fan and an Auto Electronic Choke system for simple “one touch” starting. All 400s have a fully independent, double A-arm front suspension that eats up gnarly terrain and, like the rear suspension, features preload-adjustable shocks.
Other premium features include a 2-inch “automotive style” receiver hitch, handlebar-mounted electronic 2WD/4WD switch for quick  hifts, 25-in. Carlisle Badland XTR radial tires and large 4.75- or 6.5-
gallon fuel tanks. And there is the best-in-class ground clearance (12 inches on FIS machines), rack capacity (100 lbs. front/200 lbs. rear) and suspension travel (10 inches on FIS machines).
Adding convenience to the 400 class machines are features like Start-In-Gear, zero-maintenance suspension bushings and sealed drive shafts, a full-length plastic skid plate that glides over rough terrain and the single-lever, hand-operated hydraulic disc brakes (front and rear).
Features
  • Fully Independent Suspension or Independent ACT
  • Adjustable preload shocks
  • 12 inches industry leading ground clearance (FIS) 10.8” VP Models
  • 10 inches front and rear suspension travel
  • SpeedRacks are standard
  • Fully automatic transmission or Manual 5-speed w/ Hi-Lo range
  • Reliable 4-stroke engine
  • On-the-fly electric shift 2- to 4-wheel drive with front locking differential
400 Auto FIS & LE  Specifications
  • Engine:  SOHC 4-stroke 4-valve
  • Displacement: 376
  • Bore x stroke: 82.0×71.2
  • Compression ratio:
  • Carburetion:
  • Ignition:
  • Transmission: Automatic CVT with
    EBS
  • Final drive: 2 / 4 WD + Front
    Differential Lock
  • Frame:
  • Suspension front / wheel travel: 10.00 / Double A-Arm
  • Suspension rear / wheel travel: 10.00 / Double A-Arm
  • Front tire: 25×8-12
  • Rear tire: 25×10-12
  • Front brakes / rear brake: Hydraulic Disc / Hydraulic Disc
  • Overall length: 84.5
  • Overall width: 47.5
  • Wheelbase: 50.0
  • Ground clearance: 12.00
  • Seat height:
  • Lighting:
  • Rack capacity, front / rear: 100 / 200
  • Towing capacity: 1,050
  • Fuel capacity: 6.5/24.6 L – Rear
    Mounted Tank
  • Dry weight: 669
  • Instruments:
  • Color choices:
  • MSRP:
400 Manual FIS Specifications
  • Displacement: 376
  • Carburetion:
  • Ignition:
    EBS
    Differential Lock
  • Frame:
  • Wheelbase: 50.0
  • Seat height:
  • Lighting:
  • Rack capacity, front / rear: 200 / 1,050
  • Towing capacity: 16 Amps
    Mounted Tank
  • Dry weight: 663
  • Instruments:
  • Color choices:
  • MSRP:
 400 Auto VP Specifications
  • Displacement: 376
  • Carburetion:
  • Ignition:
  • Transmission: Automatic CVT w/EBS 5
  • Final drive: 4WD
  • Frame:
  • Suspension front / wheel travel: 8.5 / Double A-Arm
  • Suspension rear / wheel travel: 7.2 / ACT
  • Overall width: 46.5
  • Wheelbase: 50.0
  • Ground clearance: 10.75
  • Seat height:
  • Lighting:
  • Fuel capacity: 4.75 / 18 L – Center
    Mounted Tank
  • Dry weight: 616
  • Instruments:
  • Color choices:
  • MSRP:
 400 Manual VP Specifications
  • Displacement: 376
  • Carburetion:
  • Ignition:
  • Transmission: 5 Speed w/Hi-Lo Range
  • Final drive: 4WD
  • Frame:
  • Wheelbase: 50.0
  • Seat height:
  • Lighting:
    Mounted Tank
  • Dry weight: 609
  • Instruments:
  • Color choices:
  • MSRP:
