2009 Can-Am Renegade 800R EFI
Can Am has become famous for their ability to blur the lines of all current classification of ATV. Nowhere is this phenomenon more evident than in the Renegade series. Boasting a fuel injected 799.9 cc v-twin engine mounted to a fully automatic (CVT) transmission, the Renegade 800R is the epitome of utility-quad power in a sporty chassis.
Model Type |
Sport |
BASE MSRP(US) |
,499.00 |
Warranty |
6 month |
Engine: |
Engine Type |
V Twin |
Cylinders |
2 |
Engine Stroke |
4-Stroke |
Valve Configuration |
SOHC |
Displacement (cc/ci) |
799.9 / 48.8 |
Carburetion Type |
Fuel Injected |
Transmission: |
Transmission Type |
Continuously Variable (CVT) |
Primary Drive (Front Wheel) |
Shaft |
Reverse |
Yes |
Wheels & Tires: |
Front Tire (Full Spec) |
ITP Holeshot 25 X 8-12 |
Rear Tire (Full Spec) |
ITP Holeshot 25 X 10-12 |
Brakes: |
Front Brake Type |
Dual Hydraulic Disc |
Rear Brake Type |
Hydraulic Disc |
Technical Specifications: |
Wheelbase (in/mm) |
51 / 1295 |
Dry Weight (lbs/kg) |
607 / 275 |
Fuel Capacity (gal/l) |
5.3 / 20 |
Seats: |
Seat Height (in/mm) |
34.5 / 877 |
Number Of Seats |
1 |
Drive Line: |
Driveline Type |
Selectable 4X2 / 4X4 |
Number Of Driveline Modes |
2 |
Limited Slip Differential |
Standard |
Differential Lock |
Standard |
Storage: |
Rear Rack |
Standard |
Lights: |
Halogen Headlight (s) |
Standard |
