ARGO Evolves the Sherp: Meet the Sasquatch
ARGO says a new king of off-road will be crowned.
The story begins a few years back when Canada’s ARGO became the official importer of the legendary Ukrainian Sherp. It was called the Centaur under ARGO badging.
ARGO took what it learned working on the Sherp and elevated it to the next level. According to them: The new ARGO Sasquatch will be soon crowned the king of off-road amphibious vehicles, so we knew we had to perfectly match the comfort to the capabilities. That’s why we partnered with Custom Products, a premier cab fabrication company, to provide a cockpit experience second to none. You won’t believe your eyes. Or your ears.
ARGO QX4 CREW CAB
Ultra-Quiet
Full Panoramic Viewing with UV protection
Premium Ergonomically Designed Interior
Fully Integrated Climate Control System
ROPS 3471 Certified
Flashing LED Safety Marking Lights
4 Passenger/3-Point Safety Belts
Front and Side Doors with 3-Point Contact Safety Certification
Transparent Emergency Roof Hatch
Designed for Off-Road/Amphibious Use
Bluetooth Radio with Overhead Speakers
High/Low LED Headlights with Daytime LED Running Lights
Full Interior LED Lighting
ARGO INFOTAINMENT DISPLAY
EXPLORE CONFIDENTLY
Traveling through the bowels of earth’s darkest, wettest, and most extreme areas calls for the latest technology to help you reach your destination safely. The new 12” color ARGO Infotainment Touch Display is loaded with integrated features to provide real-time vehicle performance information while the ARGO Terrain Control System (TCS) provides one touch preset buttons to match the terrain anywhere on the planet.
Large 12” color touchscreen
Vehicle operation controls
Speed, RPM
Fuel levels
Gear indicator
Air inflation controls
Inclinometer
Integrated vehicle health information
Temp readings
Oil pressure
Engine performance
Battery voltage
Navigation
Day or nighttime mode
Rear camera viewing
TRANSMISSION
MOVE EFFORTLESSLY
When you go where others can’t, you’ll need the capability to turn at a moment’s notice — even in extreme terrain conditions. The HDT Automatic e-Steer transmission was specifically designed for the ARGO Sasquatch by its parent company, ODG. ODG has been perfecting high-quality transmissions since 1962 and holds a patent on an e-steer transmission. Grab the steering wheel of the all-new Sasquatch and navigate the world with ease.
HDT AUTOMATIC E-STEER TRANSMISSION
H, L, N & R gear selector
Torque sensing
Steering wheel controlled
Power steering
True Zero-Turn
Drive by wire system
Lithium-titanate battery package
High-output alternator charging
Performance that’s no hoax.
The drivetrain on the new ARGO Sasquatch is industry leading. There’s no doubt about it. The ARGO Instant Torque Clutch (ITC) couples the Doosan three-cylinder 1.8 L high-output turbo diesel engine with our HDT e-Steer Transmission through a final drive gearcase powering you on land or water or through that nasty, murky sludge.
ARGO Instant Torque Drive System (ITDS) dramatically improves low-end torque while providing the optimal gear ratio, automatically shifting seamlessly through the full range utilizing the massive torque and power of the engine. Climb aboard to experience class-leading power-to-weight ratio and total performance that will leave skeptics, believers.
DRIVETRAIN
HDT e-Steer™ Automatic Transmission
Enclosed final drive gearcase
Steering wheel-controlled power steering
Wide range of operating temperatures
XT328 TIRES
BEST TERRAIN TIRE. FACT, NOT FICTION.
The all-new ARGO XT328 71” tires are larger than life. These patent pending tires have been put through countless extreme terrain tests to swim, climb, and perform like no other amphibious offroad vehicle tire. With a unique cupped-to flat-tread pattern, the ARGO XT328 tires provide superior water propulsion, excellent grip for sidehilling and extreme traction for overcoming earth’s treacherous terrain.
ARGO XT328 TIRES
New 71×23-25 Patent Pending Design
Unique Flat and Cupped-Tread Pattern
Developed through Fluid Simulation
Perfected through Field Testing
ARGO Terrain Control (ATC) Inflation Management
5-valve Independent Cold Air Inflation with Electronic Pump
Programmed One Touch Terrain Tire Pressure Preset Buttons
Engineered Matched Wheels with Beadlock Rings
Secures Tire Bead to the Wheel for Low Pressure Usage
Added Strength
Debris Deflection Center Enclosure
Increased Buoyancy
ARGO FLEXBOX
BIG WITH PURPOSE.
Meet the all-new ARGO Sasquatch XTX. This gentle giant has plenty of cockpit capacity and creature comforts for your four-person team to get the job done right no matter how far you need to travel. Plus, the durable FlexBox is built to handle heavy gear and equipment with multiple tie-down capabilities and additional sealed storage. Go Anywhere with your secured load and do what others think is impossible.
ARGO FLEXBOX
57.5 cubic feet of total storage in-box capacity
Built from durable construction materials
Sealed bed floor with two drain plugs
Lockable 3.8 cubic feet side storage box
Multiple tie-down capabilities
Side swinging lockable end gate
Hinged fold down ladder for easy accessibility
Rear cargo 2800 Lumen LED light
The only downside is this type of performance won’t come cheap. While ARGO had yet to announce a price, do keep in mind the Sherp pricing looks like this:
Sherp Pro $115,000
Sherp N $126,000
Sherp Ark $375,000
You can be pretty confident the Sasquatch will be at least as much.
More information can be found here.
