Ask The Editors: Mystery of the Check Engine Light
Dear ATVC: Does anyone know where I can find a pdf version maintenance manual for a Linhai 520?
The engine light comes on after a couple of seconds after starting it (it flickers). Then after shutting it down and waiting 10 seconds and then starting it again (2 or 3 times) the engine light stays off.
What are the parameters that can cause the engine light to come on?
Well the good news is we have your maintenance manual PDF below. The bad news is that the Linhai 520 instrument cluster does not contain an engine light (indicators only for neutral, high beam, signals, reverse, coolant temp, and low fuel). We can’t be sure what indicator you are seeing flash but hopefully the manual points you in the right direction.
Service manual PDF download here.
You must be logged in to post a comment.
