Because Sometimes Carrying a Spare Belt is Priceless
Belts do more than hold your pants up.
The Savage UTV Case is the Off Road Industries FIRST and ONLY storage case that is 100% air tight, (IP67 rated waterproof), and universally mounts to any size roll cage. The Savage UTV case can be used to protect anything you take on the trail, but was specifically designed to protect (2) UTV drive belts from all major UTV manufacturers. Whatever environment you drive in and however aggressive you push your vehicle, Savage UTV has you protected.
Each case is constructed of injection molded UV resistant ABS and is 100% MADE IN THE USA. Stainless steel mounting brackets, hardware, and a foam insert are included with each case. The included hardware mounts to tubing sizes 1”-2”, but will work with any size hose clamp. The Savage UTV case can also be mounted to any flat surface and can be locked using any masterlock type of lock. Each case comes with a full manufacturer warranty and 30 day return policy. Machined aluminum mounting options and other accessories can be found at www.savageutv.com.
Each Savage UTV Belt change kit contains the following:
(1) Savage UTV Case with mounting hardware
11″ Needle Nose Pliers
18mm Utility Knife
Ratcheting screwdriver with 8mm, 10mm sockets
(Drive belt not included)
