GBC Creates UTV Tire That You Customize on the Fly
Flip around tire for how you roll.
Until now, when you selected a new tire for your UTV, you looked at the facts, compared them to the terrain you ride and pulled the trigger when these things lined up. GBC says that kind of thinking is in the past. Introducing the Kanati Terra Master tire, the industry’s first UTV tire with an asymmetrical non-directional tread pattern. What’s that mean? The way you mount it will completely alter the handling and terrain it masters.
This specially designed tread pattern gives you the benefits of two tires in one. With two distinctive sides to choose from, you can customize your tire set up to your vehicle application, and your driving style.
Side A – Recommended mounted out for soft to intermediate terrain
Side B – Recommended mounted out for intermediate to hard terrain
The carcass profile is optimized for forward traction and side bite, all while having a lightweight steel-belt construction. The Kanati Terra Master is the next level of performance for today’s high performance side-by-sides, proving once again that GBC is a leader in innovation for the ATV and SXS Markets.
Product Highlights:
Steel belted radial design for stronger core and greater wear resistance
10-Ply Rated Construction
Asymmetrical tread pattern for dual benefits and performance characteristics
Meets and exceeds DOT standards
Designed to combat a wide variety of terrains and conditions
Non-Directional design for excellent responsiveness in any direction
Powered by years of research and field testing
