Let’s Check Out the 2019 John Deere Line
What’s JD cooking up for 2019?
When we think of side-by-sides often the first brands that come to mind are Yamaha, Can-Am, Polaris. And while there is no denying their dominance of the sector, the popularity of the vehicles is such that it has allowed for some unlikely brands to show off their stuff.
John Deere has been making off-road transporters since 1987; their first official Gator coming on the scene in 1992.
These days their line has evolved into a versatile example of UTV awesomeness. Let’s take a closer look:
John Deere RSX860
The sporty RSX860 comes in three trims; the I, E & M. Each is powered by a 62-horse V-twin with electronic fuel injection. A CV-style transmission puts the power to the soil. The RSX860M model comes with standard (EPS) electronic power steering.
Engine type: Four-valve V-twin
Displacement: 839cc
Suspension:
Front Dual A-arm/9.0”
Rear Multi-link semi-trailing arm/9.0”
Length/width/height: 90.0”/48.0”/68.0”
Fuel capacity: 7.4 gal.
Dry weight: 1430 lb.
Towing capacity: 1200 lb.
Bed capacity: 800 lb.
Price: Starting $12,299
John Deere XUV560E
The 560 may be the smallest offering on the line but don’t let that fool you; the displacement (like the MSRP) is only the starting point. You can opt for an engine package as large as 839cc. No matter which you choose, you will get fully independent suspension, 8-inches of travel at each wheel and a bed good for 500-pounds of nasty. That’s the XUV590M Special Edition photographed at the top of this article (MSRP of $14,999).
Engine type: 4-valve V-twin
Displacement: 570-839cc
Suspension:
Front Dual A-arm/8.0”
Rear Dual A-arm/8.0”
Length/width/height: 115.0”/48.0”/74.0”
Fuel capacity: 4.9 gal.
Dry weight: 1270 lb.
Towing capacity: 1500 lb.
Bed capacity: 500 lb.
Price: Starting $8,139
John Deere XUV855M S4
Sometimes you need a machine that can haul yourself, your bestie, a pair of mutual friends and all your gear. JD gets it. A liquid cooled diesel and full shaft drive mean smooth sailing all the while.
Engine type: Diesel
Displacement: 854cc
Suspension:
Length/width/height: 154.0”/62.0”/75.0”
Fuel capacity: 7.3 gal.
Dry weight: 2018 lb.
Bed capacity: 1000 lb.
Price: Starting $17,589
This is actually just the tip of the Deere iceberg; they still offer work Gators in trims from gas, diesel to full electric. They also have a military line of machines. To check them all, click here.
