New Reverse LED Light Kit for Polaris ATVs
Have you ever strained your neck to look behind when backing your machine up only to think – I can hardly see a thing?
PowerMadd has just released what you’re looking for in the Automatic Reverse LED Light Kit for Polaris ATVs. This kit is a programmable unit that can be used on many different models. Once installed, the LED light will turn on automatically once the machine is shifted into reverse. The LED light is IP67 rated. It can be mounted to the rear luggage rack of the ATV with the included clamps.
This kit can be removed from any Polaris ATV and reprogrammed to another as long as the fitment is compatible.
Specifications:
Automatically turns on when in reverse
Plug’n Play connectors
Programmable
Manual override switch
Power: 12 Watt
Lumens: 800 lm Flood
Waterproof: IP 67
Color temperature: 6000 K
LED Color: white
Life time: 30000 hours
Mounting brackets included
Housing material: Aluminum
Polaris ATV Automatic Reverse LED Light Kit
Part# 66007
MSRP: $120.00
You must be logged in to post a comment.
