Pro-Tec Moflow Answers the Airbox Conundrum
We here at ATV Connection know a thing or two about conundrums. Take for example the great air-box debate. Your ATV’s engine is, at its most fundamental level, a glorified air pump. The more air it can gulp, the better it breathes. The better it breathes, the better it performs. The simple answer should be to pop the lid and let it swallow as much air as possible right? Well maybe if you rode in a sterile environment.
However since ATVs and off-roading sort of go hand-in-hand, keeping dust, grime and grit out of your engine’s intake is critical.
Pro-Tec has the corundum-killer in the form of its high performance / high flow Moflow airbox lids for most sport ATVs. Designed to replace the restrictive stock airbox lid, Pro-Tec’s Moflow airbox lids will increase intake airflow and reduce intake air restriction. The Pro-Tec Moflow airbox lids are must for modified ATVs that require additional intake airflow or for any Sport ATV owner who just wants more horsepower. This item works especially well when used in conjunction with an aftermarket exhaust system or any other item that would benefit from improved intake air flow.
Manufactured from aluminum for strength, laser cut for a perfect fit and anodized black for lasting good looks. The Pro-Tec Moflow airbox lids include a replaceable, water repellent filter element that will provide air filter protection from water and other debris while providing maximum airflow. For those who choose to ride without an airbox lid the Pro-Tec Moflow airbox lids are a great alternative to maintain performance while extending the service interval of your air filter and preventing debris from entering your airbox.
No tools are required for installation. Simply remove the stock airbox lid and install the Pro-Tec Moflow airbox lid using the stock airbox cam locks.
All Pro-Tec Moflow airbox lids have a retail price of $85.95.
Pro-Tec Moflow airbox lids are available for all years:
Yamaha YFZ450, YFZ450R, YFZ450X, Raptor 350, Raptor 660, Raptor 700
Honda TRX450R, TRX450ER
Suzuki LTR450, LTZ400
Kawasaki KFX450R, KFX400
Can Am DS450, DS450X
You must be logged in to post a comment.
