Radlites LED’s
Radlites LED’s
Micro Billet LED
Lights
by Rad Electronics
 undefined
    LED, or Light Emitting Diodes, are becoming a real popular item to add to your automobile, truck, motorcycle, ATV, boats, or any other recreational vehicle. They are small, compact, very bright, and draw very little current. RadLites from Rad Electronics come in several differnent styles and mounts to accessorize your recreational vehicle in many ways.
undefinedRadLites are available in billet and  t-bracket mounting configurations. They come in white, blue, green, red, yellow, orange, turquoise, and purple colors. Compact in size they can be mounted just about anywhere. They are great for interior and exterior lighting such as clearance lights, off road tail lights, and safety applications where visibility is needed.
undefinedAll RadLites are housed in T-6 6061 billet aluminum and are waterproof, shock resistant, and extremely small. Drawing only 30 milliamps of current, or .36 watts they will be hardly any load on your electrical system. The billet mount has a #10 stainless steel allen stud with nut and washer for mounting, and the housing is fully adjustable allowing for easy placement. RadLites have over 1 mile of visibility for exterior lighting, and are bright enough to use for interior lighing inside a vehicle.
undefinedThe T-bracket mount comes with two #6 screws and double sided sticky tape for versital mounting. They have the same billet waterproof housing as the billet mount.
undefinedThe 1157 and 1156 led lights are the newest in the line of LED’s from RadLites. They are available in 15 segment 3 wire, (red or amber) mounted on 1″ round boards for brake and running lights. Coming soon are rectangle boards in 18 sement 3 wire in 5 1/4″ X 3/4″, 8.8″ 5 LED, and 2.2″ 2 LED.
undefinedOur 94 Honda 300EX was a prime candidate for testing out the RadLites. After installing a custom basket on the rear and moving the tail light from the stock position you can see what the consequences where. First time we wheelied the quad it broke the tail light. The solution was to  mount two red Billet RadLites one on each side of the basket. They are now protected and the two lights are plenty bright for night time riding.
undefined also has available micro switches, fuse holders, connectors, wiring kits, complete underbody kits, and new three wire conversions for RadLites. (For brake, turn and running lights.      All LED lights come with 1 yr. warranty and are proudly made in the USA.To complete the installation of your LED lights, Rad Electronics
