Review: 2025 Polaris GENERAL 1000 XP
2025 Polaris GENERAL 1000 XP Review
The GENERAL was born out of necessity.
There was a time when membership into the Polaris SxS society placed you in one of two camps – If it was sheer performance you sought, you were a member of Team RZR and if it was utility you were after, you found yourself on Team Ranger. And all was balanced in the off-road world.
Of course a pretty sizable market gap opened up before long – there were riders who didn’t want to have to choose. What about a SxS that offered up snappy performance and long travel suspension with a heavy duty winch up front and a dump bed out back? What would happen if you took the performance of the RZR and tuned it for the trails but kept the work-friendly elements of the RANGER intact? The answer is the GENERAL.
We took delivery of a 2025 GENERAL XP 1000 Ultimate in Indy Red scheme for purpose of testing just as a very late Western NY summer began to get underway after a rainy, cold spring. The GENERAL XP 1000 comes in three trim levels: Sport, Premium and Ultimate. The MSRP starts at $23,999 at the Sport trim and bumps up to $28,999 for our unit tested here. That additional 5-large gets you a 7″ display powered by RIDE COMMAND with integrated rear-view camera, Rockford Fosgate Stage 3 Audio package, convex rear-view mirror and a padded center console. And, of course, some new colorway choices.
This is all pretty impressive when you come to realize that all of the GENERAL XP 1000 trims come ready to rumble: 600 lb. dumping cargo box, 14″ of suspension travel, high clearance A-arms, a Polaris HD Plus 4500 lb. factory winch, Poly roof, low-profile bumper, 30″ Pro Armor Crawler XG 8-ply tires, On-Demand AWD with Versatrac Turf Mode and premium doors.
But since you didn’t come here to read the spec sheet, let’s talk about what it’s like to climb in and tackle the trails in a GENERAL.
Climbing In
The GENERAL leans a little bit more toward the RZR side of the equation when you approach it and climb inside. If this doesn’t mean anything to you, think high clearance with a deliberate step up, bucket seats rather than bench, doors that open forward like a car and a high center console.
The view forward is very clear and commanding, with the driver feeling well above the fairly-short hood.
Powering the machine is a 100-horsepower, 1000cc (999 actual) DOHC twin-cylinder engine that fires up with a smooth, steady rumble. Gear selection is accomplished via a center console lever (with excellent actuation) and rocker switches to the left of the steering wheel to set transmission between AWD, rear wheel or Versatrac (which is essentially single rear wheel drive).
Blast off isn’t only silky, it’s really whatever you want it to be. Go easy on the pedal and the GENERAL offers gobs of usable low end grunt – almost to the point of being punchy. You learn quickly to go easy on the accelerator lest turn the GENERAL into a bucking bronco on the low end. Go in the middle and it’s snappy, responsive, quick-revving and happy to pull hard. Hammer it down and you better be ready – It may not be quite as potent as the RZR but it isn’t far off. The big XP will get you to the next turn in a hurry without hesitation.
We did mention the GENERAL is trail-tuned and you’ll know it in a hurry. Desert machines rev to the moon, mud machines make power off the line at the expense of top-speed but trail vehicles do their best work right in the middle of the curve. The GENERAL’s 100 hp mill is snappy and smooth all throughout the power curve and the chassis matches the engine perfectly. With a 64” wide stance and almost 14” of clearance, it offers up a unique feeling of nimbleness in the technical stuff that no pure UTV can match. The suspension is active enough to pick up small trail clutter but ramps up quickly over logs, rocks and stumps, all the while keeping the cockpit level.
Polaris engineers know their stuff – make the suspension too plush and you’re forced to deal with excessive body roll and lean; too stiff and the ride is jarring, the wheels deflecting off obstacles rather than absorbing the terrain. Walker Evans Velocity Series Shocks all around strike a perfect balance with the GENERAL’s chassis. It feels stable and confident at speed and level and active when crawling over clutter.
The whole package works remarkably well on hills as well. A good part of our testing here involves ugly inclines – as in climbing them, traversing them sideways, and, of course, descending back down. The GENERAL XP is a traction hound when it comes to dealing with elevation and there’s always plenty of power on tap to get you out of trouble. EDA is their Engine Deceleration Assist system- which feeds engine compression back through the drivetrain so as to eliminate freewheeling when gravity takes hold.
Workhorse
We could go on and on about how good the GENERAL XP is on the trails because, after all, that’s really what it’s designed to dominate but just like how we discussed at the beginning of this review, the GENERAL splits the difference between the RZR and the RANGER. This means that for every buyer interested in shredding the deep woods, there will be another looking to get more utility from the machine. To that we say not only is the GENERAL capable, it’s almost overkill for most work applications you’re going to encounter on a ranch or even a worksite.
It comes standard with the Lock & Ride Cargo system, a 600 lb dump bed, low range output that maximizes torque, 2” receiver hitch good for 1,500 pounds of towing strength and a 4,500 pound winch up front. The GENERAL works as well as it plays.
Odds and Ends
The one area we often hear complaints about when it comes to the GENERAL is that the interior isn’t as refined or as luxurious as other entries at its price-point but we pride ourselves on having tested nearly every entry in the class and could find little to complain about here. Sure it isn’t quite as exotic feeling as a comparable Can-Am, it does fit right in with the remainder of Polaris’ SxS line. It retains a bit of the spartan, performance-heavy feel of the RZR but adds some luxurious touches (especially in the Ultimate trim tested here) like that Rockford Fosgate Stage 3 Audio package and 7” full color touch screen display with RIDE COMMAND.
Speaking of, you didn’t think you’d get through this review without us gushing over RIDE Command, did you? We’ll try to keep it to a minimum as it must surely get repetitive to hear it, but RIDE COMMAND is a game changer in the off-road segment. With built-In GPS, mapping, vehicle-to-vehicle with group ride, follow the leader, & no cell-phone needed messaging, integrated rear-view camera, Bluetooth & USB smartphone connectivity, AM/FM & weather radio, & in-vehicle communications capability, it’s way too easy to become dependent upon this inclusion. Trust us, we ought to know. When Polaris takes these things back, we’re lost without it – sometimes literally.
Braking is excellent with 4-wheel hydraulic disc / dual-bore calipers all around.
Conclusion
You can almost look at the GENERAL as purchasing a couple SxSs in one. It’s equally adept in group trail rides as it is completing tasks around the farm. We foolishly thought that when Polaris introduced the XPEDITION line (tested here) that it would sort of obsolete the GENERAL but we can attest this is one of those instances we are glad to be mistaken. The XPEDITION might share a lot of the features and specs, but its focus is on the luxurious side of the SxS experience, with emphasis on premium interior amenities at a much higher MSRP. By comparison the GENERAL foregoes a lot of the frills to deliver a very potent blend of performance and utility potential.
Perhaps its biggest flaw is simply that it does everything so well that it sort of lacks a gimmick to make it stand out in the crowd. The GENERAL can’t boast the highest horsepower rating, the fastest lap time, or lift for maximum mudding potential, but it’s a low profile master in the real world – you know, the place the majority of us work and play daily. Best of all, it delivers a very usable package for a surprisingly affordable MSRP. If you can live without the pampering of the Ultime package, keep in mind the XP 1000s start at only $23,999. That would be a good deal even if it excelled at only one thing!
Specs
Engine & Drivetrain
Cooling Liquid
Cylinders Displacement 999 cc
Drive System Type True On-Demand AWD/2WD/ VersaTracTurf Mode
Engine Braking System (EBS) EDA: Engine Deceleration Assist
Engine Type 4-Stroke DOHC Twin Cylinder
Fuel System/Battery Electronic Fuel Injection
Horsepower 100 HP
Transmission/Final Drive Automatic PVT P/R/N/L/H
Dimensions
Bed Box Dimensions (L x W x H) 27.5 x 43.1 x 11.6 in (69.8 x 109 x 29.5 cm)
Box Capacity 600 lb (272 kg) Rear Dumping Box
Estimated Dry Weight 1705 lbs. (773 kg)
Fuel Capacity 9.5 gal (35.9 L)
Ground Clearance 13.5 in (34.3 cm)
Hitch Towing Rating 1500 lb (680 kg)
Overall Vehicle Size (L x W x H) 118.2 x 64 x 77 in (300 x 162.5 x 195.5 cm)
Payload Capacity 1100 lb (499 kg)
Person Capacity 2
Wheelbase 83 in (211 cm)
Brakes
Front/Rear Brakes 4-Wheel Hydraulic Disc with Dual-Bore Front and Rear Calipers
Parking BrakePark In-Transmission
Additional Specifications
AudioRockford Fosgate Stage 3 Audio: (2) 6.5″ 50W Front Co-Axial Speakers & (2) 6.5″ 50W Rear Coaxial Speakers, 4-Channel Amp with Fade, Automatic Volume Level, & 5-Band Equalizer
Cargo System Lock & Ride
Doors Full Doors Standard
Electronic Power Steering High Output EPS
Hitch TypeStandard 2 in (5.08 cm) Receiver
Instrumentation
RIDE COMMAND: 7” Glove-Touch Display: Digital Instrumentation, Built-In GPS, Mapping, Vehicle-to-Vehicle with Group Ride, Follow the Leader, & Messaging, Integrated Rear-View Camera. Bluetooth & USB Smartphone Connectivity, AM/FM & Weather Radio, & In-Vehicle Communications Capable. Dual-Sweep Analog Dials with 4″ LCD Rider Information Center: User Selectable Blue/Red Backlighting & Brightness, Programmable Service Intervals, Speedometer, Tachometer, Odometer, Tripmeter, Clock, Hour Meter, Gear Indicator, Fuel Gauge, Coolant Temperature, Voltmeter, Service Indicator and Codes, Seat Belt Reminder Light, Gear Indicator, DC Outlet
Lighting
LED Headlight w/ Accent & LED Tail Lights
Other Standard Features POLARIS HD 4500 LB Winch with Synthetic Rope, Aluminum Fairlead, Rubber Isolator, AutoStop & Plow Mode. Sport Low Profile Front Bumper Pro Fit Sport Roof, Convex Rear View Mirror, Padded Console
Seat Type Bolstered Bucket Seats with Driver Seat Slider and Height Adjustable Seat Belts
Tires / Wheels
Front Tires 30 x 10-15; Pro Armor Crawler XGF
Rear Tires 30 x 10-15; Pro Armor Crawler XG
Wheels 15 in Aluminum
Suspension
Front Shocks Walker Evans Velocity Series Shocks
Front Suspension Long Travel, High Clearance Dual A-Arm with Stabilizer Bar, 14 in (35.6 cm) Travel
Rear Shocks Walker Evans Velocity Series Shocks
Rear Suspension Long Travel, High Clearance Dual Arm IRS with Stabilizer Bar, 14 in (35.6 cm) Travel
More Information
https://www.polaris.com/en-us/off-road/general/models/general-xp-1000/
