Spartan UTVs Ready For Working This Summer
Spartan Intimidator FRX UTV Line
Made in the USA and ready for the toughest jobs.
Spartan Mowers and UTVs are built by a grassroots company based in Batesville, Arkansas. The brand wasn’t proposed in a fancy conference room at the top of a skyscraper. Far from the boardroom, local entrepreneur Robert Foster sketched the first designs on a napkin at his kitchen table, and forever changed the mowing, then the UTV industries.
Quite a bit has changed over the years, but one thing remains the same—when you climb up on a Spartan mower or UTV, you’re not just sitting on a piece of lawn equipment or a regular UTV. You’re at the helm of an American Dream come true.
Spartan UTVs are manufactured by the same team behind Spartan Mowers. They’re known for their heavy-duty build quality.
Intimidator
  • Heavy-duty frame and suspension provide for a robust unit with a smooth ride.
  • With a 1250 lb bed capacity (standard model), the FRX is prepared to haul whatever and whenever needed.
  • A 2500 lb towing capacity rivals on-road trucks to help you handle the load.
  • Front and rear 2” receiver hitches allow ease of use when hauling a trailer or mounting a plow.
Maximum Comfort
  • The FRX features deluxe seating with plenty of storage to allow for a comfortable ride.
  • Optional full cab enclosures provide heat and air conditioned options to keep you at a comfortable temperature.
  • Standard LED headlights, running lights, and turn signals allow for easy set up for on-road use.
  • Standard power steering makes it easier to drive and less exhaustion during use.
The FRX stands out with features like 4-wheel independent suspension, on-demand 4WD, steel frame construction, high ground clearance, and an aggressive, utility-first design.
The FRX Intimidator comes in two flavors – Standard ($21,499 and Crew $23,699) but they can be completely customized and built to order.
More Information
To learn more about the Intimidator line or to locate your nearest Spartan dealer, head here.
