Yamaha Says Goodbye to the Rhino Line for 2014
The name Rhino has been synonymous with Yamaha’s side-by-side line since it was first introduced in the fall of 2004. Since then it has undergone various incarnations of displacement and safety standards and in fact is the machine credited with getting the side-by-side (UTV) phenomenon underway.
We were as surprised as the next to find out that for 2014 Yamaha is doing away with the Rhino line. Fear not, the “boys in blue” aren’t leaving a void where once existed a bustling line of UTVs; far from it. For 2014 they are introducing us to the Viking line-up. Replacing imagery of a leathery skinned ungulate native to Africa and Asia with seafaring north Germanic people who raided, traded, explored, and settled in wide areas of Europe, Asia, and the North Atlantic islands from the late 8th to the mid-11th centuries works for us! Let’s get to know the Vikings shall we?
Yamaha Viking 700 EPS 4×4 SxS 3-Seater
The all-new Viking is ready to conquer whatever comes its way with our most powerful 686cc, liquid- cooled, fuel injected, SOHC power plant. This new engine delivers strong low-end acceleration and pulls hard through the rpm range to deliver excellent power delivery for getting the job done or when hitting the trails.
The Viking features a large-capacity air intake system that improves overall engine performance. The air cleaner box is accessible from inside the cabin for improved serviceability.
Ultramatic transmission with dual-range (Hi/Lo) drive and reverse is the most advanced drive system available. An automatic centrifugal clutch maintains constant belt tension for reduced belt wear and uses a sprag clutch for all-wheel downhill engine braking in 4WD mode and reverse.
This true 3-passenger machine achieves driver and passenger comfort with a handhold, padded head rests, and 3-point seat belts for all riders. The superior seating position, adjustable driver’s seat, and the middle seat set back 5 degrees, provide unmatched comfort that all riders will appreciate. Yamaha’s proven electric power steering technology further reduces fatigue and strain on the driver.
Industry-exclusive three-position On-Command In/Out 4WD feature lets you switch between 2WD, limited-slip 4WD and fully locked differential 4WD- all with the simple push of a button.
The chassis design includes a convenient pass-through floor for greater ease of on-board movement, making it possible to enter and exit the vehicle from either side. The rear cargo bed is made of steel and is designed for maximum load capacity.
Every Yamaha Viking is being manufactured exclusively in the U.S.A. at Yamaha’s factory in Newnan, Georgia, for worldwide distribution.
“With the introduction of the all-new Viking, Yamaha is once again taking a leadership position in the growing multi-purpose SxS segment of the off-road business,” said Mike Martinez, vice president of Yamaha’s ATV/SxS Group. “The Viking tops its competition with precise steering and superior handling, excelling in the areas of durability, reliability, ease of use, and cargo and towing capacity. The Viking’s class-leading handling and off-road performance make it the only SxS vehicle that can claim true utility-pointed design while still providing a fun, confidence-inspiring experience in a recreational setting.”
Power comes from Yamaha’s strongest four-wheel drive engine to date – a 686cc liquid-cooled 4-stroke, SOHC, single-cylinder, 4-valve fuel-injected engine that provides peak performance at maximum capacity. This durable engine has been optimized for working conditions with strong low-end torque while quick throttle response and smooth power delivery are maintained throughout the rev range. Yamaha Fuel Injection delivers consistent starts and power even at elevation and in cold weather, and the 9.7 gallon fuel tank allows for long days in the field or on the trail.
A more powerful engine requires a more effective cooling system, and Yamaha has developed a system that keeps the Viking cool even during tough chores and at low speeds with optimum design, location and components that create the most efficient airflow through the large radiator.
While the Viking’s 700cc-class engine makes more power than some larger 800cc-class machines, the vehicle’s handling and off-road capabilities truly set it apart.
Yamaha’s three-way On-Command system, featuring 2WD, 4WD and 4WD with differential lock, is a driver-controlled system with an automotive-type rotary dial selector. This driver-controlled system gives the driver the control and confidence to lock in all four wheels based on the terrain – a significant benefit over other automated systems on competitive models.
Yamaha’s Ultramatic transmission with high, low and reverse has proven to be the industry’s most durable CVT system with dual speed gearing and an automatic centrifugal clutch that maintains constant belt tension for reduced wear and the industry’s most natural feeling all-wheel engine braking. This reduced wear has contributed to Yamaha’s proven durability, and the engine braking gives the driver confidence especially on hills and in rough terrain.
The Viking’s optional Electric Power Steering (EPS) system provides the industry’s best balance of light feeling with positive feedback from the terrain. The system reads steering wheel torque, vehicle speed, On-Command setting and negative feedback to determine the appropriate amount of assist in any given situation.
The Viking’s utility functions combined with Yamaha’s proven durability were designed for hard work, tough chores and long days in the field or on the trail. The rear steel cargo bed was purpose-built for durability and convenience. Large enough to carry a fully loaded pallet, the assisted dump bed can pack up to 600 pounds of equipment and supplies while the standard two inch receiver hitch is rated to pull 1,500 pounds.
The Viking’s chassis also contributes to its off-road capability with nearly 12-inches of ground clearance at the lowest point, a full steel/composite smooth skid plate front to back and side to side, and an optimized frame with up-turned side rails allowing for smoother transitions over obstacles. The Viking features light and natural-feeling handling in both the EPS and non-EPS configurations. The front and rear suspension outperform the competition even with heavy loads. There simply is no more secure feeling vehicle when tackling rugged terrain – especially at full capacity.
The Viking’s long-travel four-wheel independent suspension is perfectly balanced to provide a plush and comfortable ride with a quality damping feel in rough terrain all while carrying either a light or full load. The gas charged shocks help reach the delicate balance of damping and resistance with one or three people, fully loaded or empty.
The all-new Maxxis Big Horn 2.0 tires were designed specifically and exclusively for the Viking with maximum performance and durability. The new Big Horns provide an optimized balance of sidewall and tread center stiffness in a tire that delivers an excellent combination of traction, precise steering and comfort. The Viking’s large diameter front and rear brake discs with dual piston calipers on all four wheels ensure good balance and power during braking – with or without cargo. The Viking also comes equipped with a mechanical parking disc brake.
Little extras are a big deal when they help increase productivity and fun. Things like marine-grade electrical connections and wiring, a sealed maintenance-free battery, digital meter and easily accessible and serviceable foam air filter and engine are built into the Viking to help owners stay on task or trail – and out of the shop.
The all-new Viking EPS and non-EPS models will be available starting this August. Standard models come in Steel Blue, Hunter Green (with sun top), Red (with sun top) and Realtree AP HD camo (with sun top). The non-EPS models start at $11,499 MSRP while the EPS models start at $12,499 MSRP. A Special Edition Tactical Black model will be available in spring 2014.
Details can be found here: www.YamahaOutdoors.com
