My Sunl 150cc will barely start and won't idle
Old Sep 14, 2009 | 02:52 PM
jamesrb's Avatar
Default My Sunl 150cc will barely start and won't idle
I just bought a used Sunl atv 150cc and it will usually start after a couple of cranks. when it does start though, i can't get to stay on. It always dies. it has plenty of gas and the battery looks good. Any ideas?
by the way, i do now that sunl is a peice of junk but it was cheaper than the others.
Old Sep 14, 2009 | 02:59 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum jamesrb !
Have you tried adjusting the carb at all?
Old Sep 15, 2009 | 12:29 PM
jamesrb's Avatar
No i havn't, i wanted to try all the eay stuff first lol, but do you think the idle might just be set too low and if so how do you adjust it?
Old Sep 15, 2009 | 12:44 PM
KTM Patrol
Former Chinese POW!
Its a good place to start...idle screw will be sticking out of the side of the carb with a spring under it...with all the different carbs used it could be on either side.
Old Sep 15, 2009 | 01:01 PM
fourwheeldrive's Avatar
Full Time DAD!
The question in my mind is once it starts, can you keep it going if you apply the throttle? If it's something as simple as the idle being set too low, you should be able to keep it running with the throttle being applied slightly. If this is not the case, the idle circuit, and others such as even the main jet, may be stopped up and require the carb to have a thorough cleaning with carb cleaner and using compressed air to blow through all the holes in it.
Just my .02 cents. You can keep the change!
Old Sep 15, 2009 | 02:06 PM
jamesrb's Avatar
Hey thanks guys, it started up and idled just fine now, i guess the idle was just set too low. it runs like a champ now though!
Old Sep 17, 2009 | 04:57 PM
KTM Patrol
Former Chinese POW!
Glad to hear you got it going...
Old Sep 27, 2009 | 08:58 AM
ranger12's Avatar
Default atv wont stay running ???????
try this link and it will show you how to set or fix your carb.
250 ATV Carburetor Video - Reliable ATVs
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
Jaster94
3) General Discussions..
May 29, 2015 08:45 AM
1000gade
May 27, 2015 12:37 PM
elmer119
May 24, 2015 10:51 AM
