New SunL 135 110cc quad
Hi all, I am very new to quads and to this forum. I just got this quad for my daughter and I can't seem to get it started. It will turn over and start if I keep pressing the throttle but as soon as I let go it dies, then after trying a few times the battery dies. any help would be greatly appreciated, as I am new to quads and know nothing about them or engines.
Thanks
the mom.
Thanks
the mom.
It will be a screw sticking out the side of the carb with a visible spring on it.. The other option is some of these quads have a adjustment in the throttle cable itself.. you could get it to idle that way also..
Does it run to the point it's fully warmed up? Is the choke lever down all the way (choke off). I know my 110 is a little finicky until it's warmed. I slowly back the choke lever down until it smooths out as it warms. Mine will sit there and idle all day.
Joel
Joel
i'm still thinking fuel delivery problems. float not taking enough in and running empty. petcock valve partially plugged, something about restricting fuel flow. i can't get away from that line of thought.********reading other posts, is the gas tank/cap vented?
