any engine or carb mods to get some more power :)
110's are good quads. the Roketa models are decent. They use Locin engines.
ROKETA,atv, exercise & fitness,dune buggies,scooter,gokart,dirtbike,moped,utility vehicle,motorcycle,electric&gas scooter,water craft,golf cart,bike,quad,offroad,motorsport,jet, sand rails, moped, snowmobiles,helmet,accessories,generator,porcelain do
Roketa will send you PDF manuals in an email. Just contact them.
Upgrades:
Carb is currently a 19mm carb. You can upgrade to a 22mm carb, but NO bigger.
You can locate your CDI box and identify the pin connector. There is a Black/red wire there. Use a volt meter and test the cranking volts. If you place it on there and you get 12v dc you have a rare DC CDI, if you get no voltage with key on but get anywhere between 30-90v AC then you have an AC CDI. Make sure when upgrading your CDI box that you get one with no rev limiter and that you replace the coil and wire with it.
Exhaust~there is a few manufacturers that make exhausts for pitbikes that would increase power. I use a flashlight, and look through the back of the factory muffler. I align the baffles with a long screwdriver. This will create les back pressure and increase performance. A good exhaust runs about $200. Your choice there.
Suspension~Check all nuts bolts on all suspension parts. Then there is an adjustable lock ring at the bottom of the shocks on the front and rear shocks. Turn that ring with a large pair of channel locks to stiffen or soften the shock rebound.
Governor screw~make sure it is not restricting the throttle.
Fuel~use 93 octane and a fuel stabilizer or octane booster.
Additional upgrades would be to work on the engine parts. For the prices you can replace the 110cc with a 125cc swap. I wouldn't worry about that unless you were a racer.
Upgrades:
HighRpmRacer's Online Store - Roketa Owners Manuals- 110cc Dirt Bike - Loncin Engine Parts - Chinese ATV Parts
Most chinese quads are made by the same people and then retagged for brand names.
Frame designs can vary, engines/tranny combos are all very similar. Many parts are interchangeable. Some are specific(Kazuma)
