ZMC mini atv can't get it to idle lower. it takes off when i take break off
does anyone know how to adjust the idle on a mini chinese atv. I can't get the idle screw to make any difference. I can start it fine and even drive it. when i lift the back tire off of the ground and dont give it throttle the wheels spin faster and faster and the engine revs higher and higher. The only way i can slow this all down is by squeezing the break (left handle lever). when i have the break in the machine seems to idle fine. main problem being without the brake activated the atv will just go. am I missing something. i tried adjusting the throttle control on the right handle but that doesn't seem to solve the problem.
also does anyone know where i can get a pdf manual for a mini atv. also I should adjust the tightness of the chain. |
Check the adjuster on the cable up by the throttle. I've seen them adjusted so that they hold the throttle open too much.
it is not the adjuster cable I checked that. i tried checking Where the throttle line runs and screws in to the top of carborator. i unscrewed it and when I put it back in now i cant start the quad. i remember now at one point i noticed the throttle cable was unscrewed from the carb so i just screwed it on. it may be since then that i have had a problem with the quad moving when my hand is off of the brake. again, my idle screw has no effect when I turn it.
on your carb, where the throttle slide inserts, check to make sure it ain't in backwards. watch for the grooves on the slide and the slide guides in the carb. that can prevent the slide from properly seating
jaster 94
i tried putting it in both ways
would this cause the engine to rev high when i dont give it gas and pick the back tires off the ground? also will this effect using the idle screw? |
Originally Posted by dropquad
(Post 3020355)
check for air leaks on the intake also. cracks in rubber boots or missing O-rings on intake flanges
do i have to take the carb off to do all of this. Unfortunatly the gas tank is in the way of seeing in to where the throttle cable screws into.
(Post 3020362)
i can get the sleeve back in fine and i do feel the tension on the throttle. still not sure why the idle screw makes no difference when it is screwed in or out.
| All times are GMT -5. The time now is 04:06 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
