125 Coolster Brake Issue
Bought my kids a new Coolster but they haven't been able to drive it to much because the rear brakes keep falling off. The company sent me another set of brakes for the quad but the brake pads keep falling after riding it for awhile. Does anyone have any ideas or have documentation to see if the brakes were install correctly at the factory? Thanks
coolster brake issues
not sure if one of my kids quads has the same caliper as your 125 but we have a 2008 125 taotao i have changed the pads a couple of times theres not a whole lot to the caliper check your springs and there is also if these are the same as mine theres a flat tension type bracket that seated in the bottom of the caliper that creates a little tension on the bottom of the two pads mainly the smaller pad to hold them in once you get your caliper over the disc and get it tighten down snug use some loctite it should not fall apart.hope this helps .....
